Where on a Ricoh Aficio 2035 do you change the number of rings of the fax on the copier? I didnt find it in the user tools so am wondering where it is located. Any help appreciated, thank you.
Ricoh Aficio 2035 Fax
Re: Ricoh Aficio 2035 Fax
From the Global KnowledgebaseHow to change the number of rings until a call is detected
Print
Notify Me
Published 05/09/2007 02:23 PM | Updated 08/25/2010 01:16 AM
Answer ID 63748 | FAQ ID 118897 | Rank A2
How do I change the number of rings until a call is detected?
1. Enter SP Mode ( Service Program)
2. Select Fax SP Mode
3. Enter SP 2-103-007 (G3-1 NCU Parameter 06) and set to desired number of rings for Line 1
4. Enter SP 2-104-007 (G3-2 NCU Parameter 06) and set to desired number of rings for Line 2
5. Enter SP 2-105-007 (G3-3 NCU Parameter 06) and set to desired number of rings for Line 3
Caution: Do not set to zero
Note: Number of line options available depends upon model.
Products- US
- Ricoh
- Black & White Multifunction
- Aficio MP 1500, 1600/L, 2000/L
- Aficio MP 2500
- Aficio MP 2510, 3010
- Aficio MP 2550/B, 3350/B
- Aficio MP 2851, 3351
- Aficio MP 3500, 4500
- Aficio MP 4000/B, 5000/B
- Aficio MP 4001, 5001, 4001G, 5001G
- Aficio MP 5500, 6500, 7500
- Aficio 3035, 3045
- Aficio 3025, 3030
- Aficio 2035e, 2045e
- Aficio 2035, 2045
