AF 2090
  • antoney suresh das
    • May 2011
    • 103
    AF 2090
    Hi Guy's,
    while replacing new HDD's in AF2090 is it necessary that the HDD must be hitachi and same model?? When I replace a New Seagate 40GB HDD why is the machine not detecting the same??HELP thanks.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: AF 2090
    Note the following important points regarding HDD replacement:
    Both HDD.s must always be replaced together as one set.
    Replacing the HDD loses all document server documents, and user stampWhen the HDD is replaced, the default user stamps must be re-installed, so use
    SP5853 to copy these files from the controller firmware onto the hard disk
    The .Scan to Email. addresses are also lost by HDD replacement. However,
    addresses can be backed up with Smart Net MonitorPrint fonts must also be re-entered after HDD replacement.
    Nobody is perfect..
      • May 2011
      • 103
      Re: AF 2090
      my question is whether the new HDD have to be Hitachi or cab it be some other brand??
      thanks again for your response
      • rsyarcia
        • 711
        Re: AF 2090
        use any brand of HD but check the capacity 40X2 = 80G.
        Nobody is perfect..
        • miro
          • Feb 2010
          • 87
          Re: AF 2090
          must be original (oem)
