quick code #83
  • wilroth
    • May 2025
    quick code #83
    Gestetner 1302F machine intermitenly disconnects when receiving faxes and shows quick error code #83 on confirmation report. Any ideas what this means??
  • rthonpm
    • Aug 2007
    • 2847
    Re: quick code #83
    Line disconnect due to timeout. Generally slowing the modem speed down will help with this. Also, if this old machine has ECM be sure to turn that off as well.
    • wilroth
      Re: quick code #83
      how do you slow down modem speed?
      • Jomama46
        • 2900
        Re: quick code #83
        G3 Switch 06
        Bit Function Comments
        0-3 Initial Rx modem rate; Bit 3 2 1 0 Setting bps
        0 0 0 1 2400
        0 0 1 0 4800
        0 0 1 1 7200
        0 1 0 0 9600
        0 1 0 1 12000
        0 1 1 0 14400
        1 1 0 0 28800
        1 1 1 0 33600
        This setting is used to inform the transmitting terminal of the available modem rate for the machine in rx mode
        sigpic
        A+; Network +; PDI+
        • wilroth
          Re: quick code #83
          this is not a machine I know very well so now I need to know how to get to the switches. We have no service manual.
          • Jomama46
            • 2900
            Re: quick code #83
            User tools, facsimile features, parameter settings. Its in the operator manual. If you dont have that it can be downloaded from the Ricoh home page at ricoh-usa or ricoh-ap.
            Or call a tech
            sigpic
            A+; Network +; PDI+
