mpc 2030 no display
  • eurokris
    • 120
    [Misc] mpc 2030 no display
    hi all
    mpc 2030 no display only have green light at panel.i check in controller pcb and bicu .all have light flash.
    pls help me .urgent
    thanks
  • Oze
    Ricoh Fanboy
    • 1663
    Re: mpc 2030 no display
    Does the machine come to a ready state?
    Are you able to use the op panel keypad to operate the machine?
    If so it sounds like a blown inverter board.
    • eurokris
      • 120
      hi
      now display light got .after 20min come code sc828.
      pls anyone help me.
      thanks
      • sharpmind
        • Sep 2009
        • 478
        Is the firmware updated?
        • vargue
          • Oct 2011
          • 404
          Re: answer
          yea check that firm ware updated
          • scapin
            More than likely the touch screen has failed this is common.
            Part No: B223-9900
            Ricoh know of this problem..
            • teebee1234
              • 1670
              That's a ROM error (nothing to do with the touchscreen). You can try and do the firmware, but chances are you will have to replace the controller board.
