Lanier LD 135
  • tcypy1961
    • 773
    Lanier LD 135
    I'm having a problem getting this copier to print. The yellow and green lights at the ethernet connection are on. I'm doing the same thing I've always done yet with no luck. I'm going back Friday with another print control PCB ass'y. Any thoughts appreciated!!!
  • sandmanmac
    • 3964
    Re: Lanier LD 135
    Was this machine previously printing at the clients office? Or have you just added the print function to it? I don't have the manual for that specific machine (which i cross-reference to a Ricoh 2035Esp), so I'm not sure if this applies or not, but in the newer models, such as Aficio 3035, when the print/scan function is first installed, the Ethernet function must be initialized with SP mode 5985-001
    • Jomama46
      • 2900
      Re: Lanier LD 135
      Can you ping the machine the IP?
      sigpic
      A+; Network +; PDI+
      • Jomama46
        • 2900
        Re: Lanier LD 135
        Configure the port to use LRP, que name lp and check "byte counting enabled"
        sigpic
        A+; Network +; PDI+
