Rescue SD card for MP171-201 spf
  • ricmartinho
    • 142
    #16
    Re: Rescue SD card for MP171-201 spf
    Sorry for the late update.
    I only managed to solve the problem with a new controller.
    • peterxu256
      • Jul 2014
      • 110
      #17
      Re: Rescue SD card for MP161
      Since the SC870 disappearing by following instruction, but the tab of Email and Folder on address book was gone too.
      Do you have idea how to restore the Two tabs on address book? Otherwise users can not be registered on address book for function of Scanner. Each time scan functions(Email/Folder) must be manually input, very
      awkward. System/copy of Firmware is updated to latest v1.07, but still not solve the problem, Delivery Server is also not working (Select it On, ,but don't update..)
      Printer/Scanner card in Slot 1, the SC870 cannot be cleared, if it is inserted into service lot 2, the SC870. can be cleared. Meaning the problem is stilling existing, it seems to me it still needs Rescue Card
        • 37495
        #18
        Do SP 5846-050 and reboot.
        • peterxu256
          • Jul 2014
          • 110
          #19
          I added one more step, Do Sp 5846-051 backup, then 5846-50, after that do sp5846-052 restore, leave printer/scan SD in Service Slot 3
          Email and Folder Tab re-appearing in the Address Book, thanks. and tested both allright
          But delivery server is still not available, probably has nothing to do with SC870, problem on ScanRouter V2 Administrator , working on it.
          • pppp
            Technical specialist
            • Sep 2010
            • 43
            #20
            Update system even higher than 1.04 because in the 1.04 there were problems with address book access by web.
            At the moment there is 1.07. Be careful because 1.07 supports both kinds of controller board (tsunami issue a few years ago) and never do not downgrade system because you can use improper earlier firmware version.
            1.07 is safe
            Microsh.t is finished and Linux Rulez
