Ricoh Pro 751 thoughts
  • kingpd@businessprints.net
    • 921
    Anyone have any thoughts, good or bad on the Ricoh Pro C751?
  • CANCOUNTRY TECH
    • Aug 2008
    • 114
    Re: Ricoh Pro 751 thoughts
    I have one in the field currently.Not a bad machine still using charge rollers which only contact the cleaning roller every 2k copies.
    I wouldnt recommend these for print shops more in house printing.
    Good output from the device and can do 300gsm simplex which is good have noticed on some of the heavy silk/gloss stock you do get a few scratch lines.
    Way better than the venus model.At the end of the day its a light production so you cant expect the same work flow as the c901.Still early days though with this model.
      • 921
      Thanks for the input. I wasn't sure what kind of volume they could handle...by looks alone it looked like they could be bigtime production machines, but looks can be deceiving.
