Ricoh MP C3500
  • Charlessd
    • 16
    Ricoh MP C3500
    Help, message that has no privileges, you can: ( not enter as administrator, as it solves this problem?
  • Eric1968
    • 2458
    Re: Ricoh MP C3500
    Log in as Supervisor with no password and reset the admin password in System Settings - Key Operator Tools.
    • Charlessd
      • 16
      Re: Ricoh MP C3500
      Does not allow access to any function, it appears without privileges. Your know if I can do from the SP??
      • zed255
        How'd ya manage that?
        • 1024
        Re: Ricoh MP C3500
        As Eric mentioned, using the supervisor account allows you to set administrator account privileges. The supervisor account can only modify administrator credentials, it has no other purpose. Once having reset the administrator account, you log out of the supervisor account and log in using the administrator account.
        User Tools> Login> Username: supervisor, Password: ***leave empty***> System Settings> Administrator Tools> Program / Change Administrator>
        Alter the admin account such that the username is admin and the password is blank, save the changes. Exit from User Tools and logout. Try logging in with admin and no password (blank).
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: Ricoh MP C3500
          Sometimes these machines hide the soft login button on the LCD, you have to press the hard key on the right hand side of the ops panel above the start button, looks like a square with a key in it. Then do as Eric and zed have said. That should sort you out.
          Hit it.
          • Charlessd
            • 16
            Re: Ricoh MP C3500
            Hare attempt colleagues, thank you very much for the help, I will comment it occurred
            • keeper2ar
              • Apr 2013
              • 5
              Ricoh MP C3500
              Very usefull info guys, just used this in a locked copier and now works ok
