HELP MPC-3000 SC995 ( Not clearing )
  • Masterchief
    • Apr 2011
    • 280
    Hi Everyone
    I cannot seem to solve an issue with this MPC 3000 machine. it started with SC555 constantly, even after sc reset 5810 so i changed the PSU, and reset the SC in service Mode.
    So that did not help cause i now have SC995 which says refit the original controller board on the service manual.
    i have since refit the original PSU, i have put on another controller board unit complete from a working MPC 3000, i have formatted the HDD and done M.A.C and still no luck
    Can Somebody Please help
    Masterchief
    sigpic
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: HELP MPC-3000 SC995 ( Not clearing )
    From the Guide of Goose...
    SC 555 Heat roller lamp on full power - A level code, reset with SP5-810
    SC 555 Heat roller lamp on full power - check lamp with meter, replace as needed
    SC 555 Heat roller lamp on full power - replace PSU
    SC 995 Controller board mismatch - Wrong controller installed
    SC 995 Controller board mismatch - replace IO board
    SC 995 Controller mismatch error - NVRAM defective
    SC 995 Controller mismatch error - install correct controller board
    SC 995 Controller mismatch error - see TSB# 003 "Technical Tips" #4 Swapping PCB's between machines
    Looks like the nvram could be baked, but that TSB might be worth a look. Especially seeing as you've replaced the PSU already and the correct controller. Have you tried a fresh fuser in it too?
    Hit it.
    • Masterchief
      • Apr 2011
      • 280
      TonerMunkeh
      I would like to thank you for your quick reply and tips.
      I replaced the I/O board and that sorted the problem :-) thanks for pointing me in the right direction
      Masterchief
      sigpic
      • TonerMunkeh
        Professional Moron
        • 3865
        You're very welcome, thanks for the feedback.
        Hit it.
        • vargue
          • Oct 2011
          • 404
          The DIP switch on the BCU is
          incorrectly set. then turn off machine and turn on or try to raise switch number 3
