Hi, one simple question, are Aficio 3245C drums interchangeable with AP3800c. I need a little help from a friend, No manuals at hand. Thanks
Drum units
sigpicWe can all Win, but at the end we all loose. Save the greyhound -
Re: Drum units
It seems to me that I heard that the two had different length waste toner "auger" sections at the rear, so the waste toner would just drain down into the rear drive section rather than the waste bottle, but I'm not sure at allComment
Re: Drum units
Sandmanmac is correct about the different lengths of the waste nozzle, but the symptom you will get is the waste toner backing up in the drum unit and smearing on the drum surface (eventually it will seize up). The reason is that the spring loaded nozzle cover doesn't open because it's to short. I speak from experienceComment
Re: Drum units
