MPC2500 tray 1 paper no detacted
  • bertley
    • Jul 2025
    [Misc] MPC2500 tray 1 paper no detacted
    My mpc2500 tray 1 always bring problem, already add paper in, but
    still show me add paper simbol. please help and give some idea.
  • sharpmind
    • Sep 2009
    • 478
    Re: MPC2500 tray 1 paper no detacted
    Perform output check for tray lift motor 1 to know if it is working fine or not. If you find it is still good, then there is a problem in the paper feed unit. Remove the paper feed unit and clean the sensors in it. Put the paper feed unit back and check it again.If same problem occurs, replace the sensors.
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 417
      Check the paper end sensor flag on the feed unit, if you are lucky then the flag itself will be broken. If you're unlucky then the bracket it clips into will be broken and the easiest thing to do would be to replace the whole assembly.
