net work issue
  • vargue
    • Oct 2011
    • 404
    [Misc] net work issue
    machie write massege above ip address and subnet mask and defaul gatway (103) what that mean
  • sharpmind
    • Sep 2009
    • 478
    Re: net work issue
    Check properly the IP address, subnet mask and gateway address.If one of these informations is wrong, then the error message you mentioned will appear.
    Make sure the IP address you entered in the machine is not used by other device.
    • vargue
      • Oct 2011
      • 404
      Re: net work issue
      indeed of course i detect... my model is dsm 725 what is that number thanks
      • Jomama46
        • 2900
        Re: net work issue
        post a copy of the printer config sheet
        sigpic
        A+; Network +; PDI+
        • vargue
          • Oct 2011
          • 404
          Re: net work issue
          all fine but i turn off Dhcp all fine and report come out properly how i make reset to all net work in machine
          Uploaded with ImageShack.us
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            Re: net work issue
            with a bomb, LOL
            sigpicWe can all Win, but at the end we all loose. Save the greyhound
            • Jomama46
              • 2900
              Re: net work issue
              5801-11 will reset all nw settings to default.
              Is it on a network?
              Do you understand network settings?
              Are you a technician?
              sigpic
              A+; Network +; PDI+
              • sharpmind
                • Sep 2009
                • 478
                Re: net work issue
                103 is an error which tells you to check the network settings of the machine because one of the informations in the printer configuration (IP address, gateway address and subnet mask) is incorrect.
                Based on your configuration sheet, it seems that the gateway address is incorrect.
                Who give you the network information?Sometimes the client gives wrong information which brings you too much headache.
                • vargue
                  • Oct 2011
                  • 404
                  Re: net work issue
                  thank yo master professional technitcian for that notice
                  • iMind
                    • Mar 2008
                    • 1116
                    Re: net work issue
                    ...and your subnet mask is also incorrect should de 255.0.0.0 according to your IP address.
                    • Jomama46
                      • 2900
                      Re: net work issue
                      and that gateway, did you just pick that out out of thin air?
                      sigpic
                      A+; Network +; PDI+
                      • vargue
                        • Oct 2011
                        • 404
                        Re: net work issue
                        this gateway is written in my pc config info i didn't get that from any where yo know!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        • teebee1234
                          • 1670
                          Re: net work issue
                          Put it back into DHCP mode, reboot and print out the config page again. Please post that for us.
                          • vargue
                            • Oct 2011
                            • 404
                            Re: net work issue
                            it's ok now massege disappear i make reset to network option and make reboot machine .thanks my guies so much .but subnet mask didn't pertained to this issue so far .
                            • Jomama46
                              • 2900
                              Re: net work issue
                              so you're back on dhcp?
                              sigpic
                              A+; Network +; PDI+
