MP2510 Print Scan Install
  • copyaction
    • Oct 2007
    • 991
    I had posted about this last week thinking that the 3025 and MP2510 used the same print scan options.
    Having been told they are different I now got the print scan dimm and sd card type 3010 but when I installed them in the 2510 they are not recognized, neither the buttons nor in user tools or SP mode.
    Is there another step I need to complete the installation, it also has fax and document server and they are working fine.
  • teebee1234
    • Jul 2008
    • 1670
    Re: MP2510 Print Scan Install
    You also got a hard drive with that also, didn't you (required)? This is from the manual (I've attached the complete section that gives you all the info you need) ...
    20. Enable the network and USB functions.
    • copyaction
      • Oct 2007
      • 991
      Thanks, that was it.
