Connect AF2020D to Mac
  • +ve charge
    • May 2008
    • 87
    Hi.. Never had to connect a machine to an Apple before, I have only worked in windows environment. Just came across a customer who requires this done. Pls let me know the procedure to connect an AF2020D to a Apple using Mac OS X version 10.5, Is there anything I shud know before I attempt this.
    Yr replies appreciated. Thanks in advance.
  • Ollie1981
    Toner Monkey
    • Mar 2008
    • 417
    Re: Connect AF2020D to Mac
    If the machine doesn't have the Postscript option it's a non-starter.
    • Jomama46
      • 2900
      install the ps option. download the 10.5 dmg . move the dmg to the desktop and doubleclick it to start.
      Locate the printer in the Printers and Faxes. if its on the network it will find it.
      sigpic
      A+; Network +; PDI+
      • sandmanmac
        • 3981
        I've connected several Ricohs (MP161, 2000, 2510, to name a few) to MAC without PS, by entering the IP address to browse for the printer, when detected, use the drop down menu next to "use this driver" (or whatever it's called), and select the "generic guttenprint" driver.
        I believe it's the PCL XL language that allows this function
        I don't believe it necessarily allows for all the functionality of the printer (ie: Duplex) but it works well otherwise
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          • sandmanmac
            • 3981
            Good tips there IMind. I didn't know "guttenprint" wasn't available on "Tiger", or that it didn't support colour. I'll definitely keep that in mind.
            • +ve charge
              • May 2008
              • 87
              Thank you for your opinions. Today I will put your comments into practice and let you know the outcome. Did I say thank you? Well again. Thank You!
              • jonhiker
                • 661
                Actually there are mac drivers for the color machines. i just searched at riucoh-usa.com and found 10.1-10.7 drivers for the mpc5000 and mpc 3500.
                • +ve charge
                  • May 2008
                  • 87
                  Success is sweet, but success after seeking help is Sweeter...
                  Used USB cable connection and did the above. Ricoh didn't pop up but NRG Dsm620d did. Customer was elated so were we. live and learn. thank you guys.
