Ricoh spc411 need to know how to get into sp mode. Thanks in advance
  • bronxizzy
    • Mar 2008
    • 23
    [Misc] Ricoh spc411 need to know how to get into sp mode. Thanks in advance
    Cant get into service spc 410 menu n forms no forms button on the 411
  • teebee1234
    • Jul 2008
    • 1670
    Re: Ricoh spc411 need to know how to get into sp mode. Thanks in advance
    Press the “Up/Down arrow” keys together for about 5 seconds, and then press the “OK” key.
    “SYSTEMver x.xx/ 1. Service” appears on the display.
    (The machine automatically goes off line when you enter the service mode.
    Accessing the Required Program
    Use the “Up/Down arrow” keys to scroll through the menu listing.
    1. Service: Controller service modes
    2. Engine: Engine service modes
    3. End: Exit service mode
    • To select an item, press the “OK” key. Then the sub-menu shows.
    • Scroll through the sub menu items using the “<>” keys.
    • To go back to a higher level, press the “Escape” key.
    Inputting a Value or Setting for a Service Program
    • Enter the required program mode as explained above. The setting appearing on the display is the current setting.
    • Select the required setting using the “<>” keys, then press the “OK” key. The previous value remains if the “OK” key is not pressed.
    Exiting Service Mode
    • Select “End” from the service mode main menu, then press the “OK” key.
    • To make the settings effective, turn the main switch off and on after exiting service mode.
