MPC2500 Can't log to SP Mode
  • mustdie
    • Jul 2011
    • 26
    Hai..I have a problem with this machine that it can't log to SP mode(107).I already change controller board but
    it still not working.So please give an idea to solve this happen.Tq
  • teebee1234
    • Jul 2008
    • 1670
    Re: MPC2500 Can't log to SP Mode
    Are you saying everything is normal but you can't log into Service Mode? If that is the case, then Service Lock is probably on.....
    Service Mode Lock/Unlock
    At locations where the machine contains sensitive data, the customer engineer cannot
    operate the machine until the Administrator turns the service mode lock off. This function
    makes sure that work on the machine is always done with the permission of the
    Administrator.
    1. If you cannot go into the SP mode, ask the Administrator to log in with the User Tool
    and then set “Service Mode Lock” to OFF after he or she logs in:
    User Tools > System Settings > Administrator Tools > Service Mode Lock > OFF
    • This unlocks the machine and lets you get access to all the SP codes.
    • The CE can service the machine and turn the machine off and on. It is not necessary to ask the Administrator to log in again each time the machine is turned on.
    2. Go into the SP mode and set SP5169 to “1” if you must use the printer bit switches.
    3. After machine servicing is completed:
    • Change SP5169 from “1” to “0”.
    • Turn the machine off and on. Tell the administrator that you have completed servicing the machine.
    • The Administrator will then set the “Service Mode Lock” to ON.
    *Save the good controller board*
    • mustdie
      • Jul 2011
      • 26
      Ya..but at the user tool there i see that service mode already OFF.But still cannot go.
      • teebee1234
        • Jul 2008
        • 1670
        You're using this pattern to enter?,,,,
        Clear Modes (yellow)>1>0>7>Press and Hold the Clear/Stop (red) key
        Are all of the keys functioning? Try entering the test screen and do a key test (Clear Modes>1>9>9>3>press Clear/Stop 5 times)
        I've had stuck/non functioning keys give me problems like this. Sometimes I had to put heavy pressure on them to connect.
        • westpest
          • Jun 2011
          • 8
          Had this recently same machine, replaced HDD worked fine, caused by sparky testing RCD's
          • vargue
            • Oct 2011
            • 404
            detect that presses they already working not defused if on of them not working properly yo can't log on to sp mode ... ok
            • 1nevster
              • Dec 2010
              • 49
              Ive had this and the firmware was corrupt, so updated firmware and it resolved not sure this is of any use if you have changed boards already as you have probably changed the nvram already with the board?
              • mustdie
                • Jul 2011
                • 26
                I already tested all button and good funtioning...thanks for your respon
                • mustdie
                  • Jul 2011
                  • 26
                  ooo yeahh..i will test it..tq
                  • mustdie
                    • Jul 2011
                    • 26
                    PLease help..Have any Idea for this happen..still can;t log until today
                    • kanagavel
                      Service Engineer
                      • Feb 2020
                      • 78
                      Hi boss, can i know, ,in administrator tool which place have the option for lock the sp mode. Please.
                      • davel
                        • Oct 2011
                        • 1107
                        Old thread but if you look in user tools you will find it.
