Hi. I've just come across an MPC 2800 that when i arrived was OK, but is reporting at least 10 sc460's in the past 24 hours and am wondering if you ended up finding a fix.
Manual says problem with HV power supply/cabling or IOB. I've re-seasted all cabling to and from these boards and checked fuses for continuity etc.
Machine is up now but i fear a repeat. Any clues? Power fluctuations?
So this could be damp paper?! I have had an MPC3500 doing this over the last few days too but it has been sitting in a very cold environment for a long time. I will have a go with some new, warm paper and see if that helps?
I don't get the error code until I run the first copy, the machine warms up and gets to ready fine.
I had this intermittant fault - try resoldering all the components on the small board located beneath the transfer roller ( mounted on right hand side opening door flap, it is the HV board for the transfer roller and can have dry joints. Thanks to Neil for helping me with this
hi there.i have a mpc4000 that is giving sc460.changed h/v board,trnsfer unit,iob and bicu.still have the same problem.it gives the code as soon as the first print comes out.machine goes to ready condition.
Hi, sorry for reliving an old post but I wanted to know if you found a solution to this error, thanks Hi, sorry for reliving an old post but I wanted to know if you found a solution to this error, thanks
