Aficio 2232c sc868-254
  • golfish8
    • Jun 2025
    cannot reset.
  • Jomama46
    • 2900
    Re: Aficio 2232c sc868-254
    SD card error. Make sure it is seated and in the correct slot. FW card goes in slot 3 (bottom). Print scan is in the top slot. Remove the SD card(s) and try again.
    The DOS option or the PS option goes into slot 2. If either has been installed in another machine, that is the problem.
    sigpic
    A+; Network +; PDI+
    • golfish8
      Thank you. The card is bad. How to flash new card?
      • Jomama46
        • 2900
        which card is it? print/scan and DOS you will have to buy from Ricoh. The postscript also, except I saw an ad around here somewhere for that one.
        sigpic
        A+; Network +; PDI+
        • golfish8
          Thank you Jomama46. Time to call Ricoh.
