sc 672
  • Muzammil
    • Aug 2025
    [Error Code] sc 672
    some one tell me how to remove sc 672 in machine model 3045 ricoh.controller board error
  • Jomama46
    • 2900
    Re: sc 672
    SC 672 Controller start up error - reload firmware
    SC 672 Controller start up error - replace controller
    SC 672 Controller start up error - replace op panel
    SC 672 Controller start up error - reseat/replace FCU
    SC 672 Controller start up error - MBU board on FCU loose
    sigpic
    A+; Network +; PDI+
    • mikadonovan
      • May 2008
      • 2931
      Re: sc 672
      As mentioned in the previous post, it could be the MBU. If the machine has a fax option installed, make sure the MBU is seated on the FCU. I've seen this on more than one occasion.
      NEVER ASSUME ANYTHING
