Transferring the address book to a different machine
  • mikadonovan
    • May 2008
    • 2931
    Hi,Guys. I have a 2051 that I am pulling and replacing with another 2051. The old machine has a TON of entries in the address book. If I back up the address book with the WIM, will I be able to download it to the newer 2051 since it is the same model, or is it machine specific? I have tried this in shop with 2 different Ricoh models, and the file was not recognized by the one I was trying to download to. I'm pretty sure I could just swap the HDDs and all would be good. I'm just looking for the easiest way to do this without having to do manual reentry. Any ideas? I thought there might be a way to upload it to an SD card, but I couldn't find it in the manual.
    NEVER ASSUME ANYTHING
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Re: Transferring the address book to a different machine
    You could try using smartnet monitor for admin and exporting them to an excell spreadsheet then sending them back to the new machine, although 2 identical machines should have no problems when copying the address data.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • rthonpm
      • Aug 2007
      • 2859
      Smart Device Monitor for Admin will do the job for you: just tell it to export the address book. Save it, and then when the new machine is in place, export to the new machine. The only thing it won't export (as a security feature) is individual passwords.
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 417
        One thing to try is backing up/restoring the address book to an SD card via SP Mode, I've done this when installing a new machine (assuming a Ricoh for Ricoh), back up the address book from the old machine to SD, download it to the new machine, BAM done and dusted. As long as the controller/GW is the same revision, it should work fine in my experience.
        Can't remember the exact SP mode, but put a blank card in the service slot (same as f/w update) and scroll through the Mode 5xxx until you see something to the effect of Address Book Backup/Restore.
        • jonhiker
          • 661
          you shouldn't have any problems using WIM to transfer from like model to like model.
          • lolicar
            You can doeven withdifferent models withthe WIM(backup andrestore)and keptthe passwords
            • mikadonovan
              • May 2008
              • 2931
              Forgot to give an update on this one. Upload to and from an SD card was under UCS settings, SP 5846 051 and 052. Quick and easy.
              • Gift
                • Mar 2011
                • 2459
                Thanks for the feedback!
                I usually try this first since it's the easiest way to do. Unfortunately my experience due to the success rate isn't great when it comes to cross-model/generation transfers. Next thing is try using the Smart Device Monitor wich usually get the job done (still not a 100% success rate).
                • Tonerbomb
                  AutoMajical Resolutionist
                  • Feb 2005
                  • 2589
                  If you do the sd card route through sp 5846 you can not transfer to a different machine, The file will be serial # specific. And no you can't rewrite the S/N on the file and get it to work. Been there Done that!
                  Mystic Crystal Revelations
                  • Llama God
                    • Mar 2009
                    • 1353
                    Backing it up and restoring it, which I do using WIM, usually works across all sorts of models. However, it mostly fails when using the address book from a colour box and trying to restore this to a mono box, probably because the fields are different.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Sure you can. I had no troubles at all loading the address book onto another 2051 with the SD card.
                      • tcs04
                        FORMER Techie
                        • 1183
                        x2!!!
                        You can use the sd card / WIM method as long as the machines have the same version GW controller even if they are different models. Otherwise SDMA is the best method.
