Ricoh MP5000 Scan to Folder issues (Windows 7 Professional x64)
  • Laserbeast
    • Aug 2025
    [Misc] Ricoh MP5000 Scan to Folder issues (Windows 7 Professional x64)
    Greetings all,
    I'm having some big problems with the scan-to-folder feature on the MP5000. It will work, but after 45 mins to an hour, it will stop working. The only fix for this is to restart the server they're being scanned to.
    We have it setup so it will scan to one workstation (Win7 Pro x64), where inside there are multiple user folders (all mapped on the MP5000 correctly) so users can pull their scans off. When it works, it works flawlessly. Then out of the blue it'll stop working.
    I've tried turning off SMB Signing, changing DNS, etc. to no avail. Does anyone have any idea what this could be? It's very frustrating and it's impacting productivity at my clients office.
    Thanks.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP5000 Scan to Folder issues (Windows 7 Professional x64)
    If it's only a problem with the server I'd tell your customer to set up an XP box to handle the scanning or just use scan to email instead. The MP5000 isn't at fault as the scanning issues are resolved after a server restart.
    Hit it.
    • Laserbeast
      Thanks for the reply. I'm hoping it's just a number off somewhere or a port not opened or something. Like I said, it works for a while and works like a charm, until it just decides to stop working. I'm more curious as to why that would happen, rather than setting up a whole new solution.
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        There are various Scan to SMB bug fixes for weird and wonderful problems via the Network support firmware.
        Latest: D0135754M / v7.37
        • Laserbeast
          Thanks Cipher. Is it true that I can't get the firmware unless I'm an authorized dealer?
          • Cipher
            • May 2006
            • 1309
            Yeah just call your local Ricoh dealership and request that the firmware be updated for your model.
            Should be a minimal charge.
            • Laserbeast
              Thanks Cipher. I took a look at the page, looks like 7.37 is already up on it.
              Here's everything:
              Module Name Version Part Number
              System/Copy 1.14 D0135751W
              Network Support 7.37 D0135754M
              Fax 06.00.00 D0135753H
              RemoteFAX 02.00.00 D0115752D
              Scanner 01.25 D0115751K
              Printer 1.14e D0135758T
              Font EXP 1.02 D0135759A
              OptionPCLFont 1.01 D0125761A
              Option PCL 1.06 D0125755G
              Network DocBox 1.12C D0115757M
              Web Support 1.60 D0135755L
              Web Uapl 1.10 D0115756F
              animation 1.3 D0135752A
              GWFCU3-10(WW) 07.00.00 D3465570G
              Engine 1.07:05 D0095160K
              OpePanel 1.08 D0091491C
              LANG0 1.07 D0091496A
              LANG1 1.07 D0091496A
              ADF 14.00 B8025603A
              Finisher 02.010:14 B8045552F
              • Laserbeast
                I'm guessing this could have something to do with it? Looked in the system log and found this:
                #[nbtd(1354)]11/11/28 12:37:48 WINS name registration: No response to server(192.168.1.254) (Ethernet) INFO:
                #[nbtd(1354)]11/11/28 12:37:49 Name registration success. Broadcast name=RNPE2A68E (Ethernet) INFO:
                #[nbtd(1354)]11/11/28 12:37:50 Name registration success. Broadcast name=WSH (Ethernet) INFO:
                192.168.1.254 is the default gateway on the network.
                • Cipher
                  • May 2006
                  • 1309
                  Cool, then it's down to good old troubleshooting.
                  When it stops working you should try doing a network capture using wireshark and see if you can find some clues.
                  Also checking the Windows event log for errors may shed some light.
                  • Cipher
                    • May 2006
                    • 1309
                    Try using a I.P address instead of a name as that would bypass any name resolution issues.
                    E.G
                    \\192.168.1.x\share
                    • Laserbeast
                      Originally posted by Cipher
                      Try using a I.P address instead of name as that would bypass any name resolution issues.
                      E.G
                      //192.168.1.x/share
                      Yea I have them all set like that. \\192.168.1.35\share\USER
                      Event log doesnt have anything special for me to be worried about. I took a look at the default gateway @ http://192.168.1.254 and looks like there may be some things with the SonicWALL crap to change.
                      I'm the second person in this office to do work like this. Relatively small, 10~ user office with some lingering network problems. It's been a bit of a birds nest but I think we're getting close to finally getting this taken care of.
                      Just have to find the SonicWALL user/pass and I think theres going to be some Firewall stuff in there for me to look at. At the very least, some ports to forward.
                      Thanks again.
                      • Cipher
                        • May 2006
                        • 1309
                        It wouldn't be the first time that firewall or antivirus caused issues with Scan to SMB.
                        Good luck.
                        • joevane
                          • May 2011
                          • 4
                          Here's everything:
                          ADF 14.00 B8025603A
                          Hello,
                          We are a Ricoh distributor in Mexico and have access to an ftp with "Tech Tool Box" and to Ricoh University where we usually find firmwares, bulletins, manuals, etc.; but the highest Network Firmware that I've found in there is 7.26 ... and it still present problems with SMB shares, could you please direct me to where I can find the new firmware?
                          Thanks!
                          • joevane
                            • May 2011
                            • 4
                            Issue has been resolved, I got the firmware directly from Ricoh Mexico... The MFP has been updated and now Scan to folder in Windows 7 works! ... Thanks
                            • joethethird
                              • Jun 2009
                              • 7
                              Joevane, you say you got the Firmware from Mexico and you can now scan to folder. Is the Firmware newer than 7.37 D0135754M ? I only ask because your machine shows 7.37 D0135754M already installed. How can I get this Firmware?Setting up a MP4001 and it is not scanning to folder in Win 7.Any help would appreciated. Thanks.
