ricoh 3228 color registration
  • mrgene
    • 53
    the machine just will not regerster I have cleaned the sensors above the transfer belt. I even tried a new belt
    is there a trick to get these machine to regester ?
    any suggestions would be thankful
  • Jomama46
    • 2900
    Re: ricoh 3228 color registration
    Clean the silver roller at the top of the xfer unit. The id sensors bounce light off of them to perform the registration. There is a rotaion sensor on that unit also which may be dirty/defective.
    sigpic
    A+; Network +; PDI+
    • mrgene
      • 53
      i replaced the three sensors behind the fuser and that fixed it
      thanks
      • Jomama46
        • 2900
        Good. Those are the ID sensors and one of their uses is to adjust the registration.
        sigpic
        A+; Network +; PDI+
