1357 with an SC495
  • Hemlock
    • 432
    1357 with an SC495
    Coming up on 2 million with about 18 months in service; had a 495 about 6 weeks ago and another today. In both cases, cleaning out the tube that runs from the hopper to the dev unit took care of the problem. Oddly, the 1107 with the same copy count and time in service (same location) hasn't had this problem yet.
    For those with experience - is this going to be an ongoing thing? Is there something in particular that causes (or can prevent) this?
    “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
  • miro
    • Feb 2010
    • 87
    Re: 1357 with an SC495
    Sorry, but you must replace toner supply pump(above dev. unit), it is only fix to sc 495
    • Hemlock
      • 432
      The pump unit itself or the motor that drives it?
      • zed255
        How'd ya manage that?
        • 1025
        Replace the pump as a unit, the valves inside become worn.
        • Hemlock
          • 432
          Gracias!
