Ricoh 3245c
  • bazza127
    Ricoh 3245c
    Hi I wonder if anyone can help me.
    If printing multiple copy's thye first to are ok then they start to get ghoasting of another part of the print on them and then they have a missed bit of print and a rough texture on that part
    thank you
  • brij
    • 11
    Re: Ricoh 3245c
    Hi
    I am assuming that you are not printing on thick paper with normal setting. normally ghosting is caused by fuser not fusing properly but in your case it cutting the prints also so i will say it's transfer unit. if it has done lot then whole unit needs replacement. I had same problem. I serviced the tx unit and replaced belt and blade but didn't help. finally replaced the whole tx unit and that fixed it. I had tried fuser before touching tx unit.
    • Eric1968
      • 2458
      Re: Ricoh 3245c
      Could be the Transfer Belt Cleaning Unit or the Fusing Unit. Could also be a bad PCU-Unit. PCU's and DV-Units last for 60k, might be worth checking.
