Ricoh MPC 3000 giving SC101,SC141,SC142,SC995
  • techie
    • May 2025
    [Error Code] Ricoh MPC 3000 giving SC101,SC141,SC142,SC995
    Hi Guys.
    Having a bit of a problem with an mpc3000.
    We are getting the sc 101,141,142,995.
    we had the copier in for a workshop service was tested for a day +- 400 copies all great.
    then 2 days later comes back with the copy with just lines, internal copy is perfect, from the Doc Feeder it starts out good then deteriorates and then sc 141 comes up! We cleaned the white reference and followed the steps in the sm! then the machine wuld come on and sc 142 would appear on the display straight after the white reference was done!
    We changed the sbu,iob,bicu boards with a working MPC3000 but now we have sc 101 as well as sc995, we have done all the setting changes for the pcb and bicu boards but still nothing.
    Reading some of your advise i see they say must change/replace fuse R59??? cannot locate this as well as reset SP 5882 to initial? does not have this on the machine?
    any help would be appreciated.
  • brij
    • 11
    Re: Ricoh MPC 3000 giving SC101,SC141,SC142,SC995
    hi
    full Memory cear is 5801 in service mode not 5882. sc 995 is the serial number error. you have to enter the serial number of the machine manually I think it's 5811. normally it's come after replacing Bicu. I think you should try replacing the exposure lamp for your codes problem.. good luck
