SC 400 on MP-C2500/4500
  • SuperLeo
    Have anyone of you gentlemen (ladies) run into the above SC code??
    I have faulty readings from the Magenta ID sensor on two machines. The SC code is triggered immedialtely at power on.
    All relevant hardware including the EEPROM on the BiCu board and NVRAM on the controller has been replaced. Firmware has been updated and the NVRAM data from another machine has been tested.
    Any advice would be greately appreciated!
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    I take it you have tried replacing the I.D sensors PCB as well?
    • SuperLeo
      • Cipher
        • May 2006
        • 1309
        You have pretty much replaced everything else.
        Hmmm interesting one.
        This calibration compensates for the transfer belt’s condition and the ID sensor condition. For example, dirt
        on the surface of the belt or ID sensor.
        VSG adjustment is always done during initial process control. But, at other times, it is only done if the VSG
        adjustment counter (SP3-510-007) is more than the value set with SP3-511-007 (default: 500) during a
        job or at job end.
        SC400 is displayed if VSG is out of adjustment range sequentially 3 times.
        So it's basically failing on step 1 of process control which is just the I.D sensors measuring the LED feedback from the bare surface of the ITB belt.
        Have you tried another ITB unit?
        Have you tested the I.D shutter solenoid from the output test?
        • SuperLeo
          Yep, all boards have been replaced. Today i operated the machine with the duplex unit open. I could see the shutter work normally. Next week i need to replace the machine for a new one..
          • tonyd
            hi
            its the bcu board. we had a machine with the same fault and the manafacturer had a bulletin on their tech support website. We tried it and it worked!!
            • SuperLeo
              • SuperLeo
                • paulg
                  • Jun 2007
                  • 278
                  Have you done the old trick of switch of sc's and made a copy if possible?
                  we have on various itbs of ricoh colours had one of the colours fail normally its to do with the charge roller or its supply for that particular colour.
                  I had a brand new out of the box itb fail on the yellow and vary patchy on one of the other colours. When the old unit was put back in the problem went away. This has also happened on 3245, cl700's and 3800cs.
                  just a thought
                  • SuperLeo
                    Hi
                    After RAM clear i was able to print, and the density is good in all colors!
                    All PCU´s, ITB, PTR has been replaced.
                    I´m thinking about making a last try with exchanging the laser unit....
                    • Cipher
                      • May 2006
                      • 1309
                      I couldn't see another BICU board making a difference after it had already been replace once by a known good one.
                      And to be honest I cannot see another laser unit doing much to fix the issue either as the service code is I.D sensor related.
                      You established in your last reply all colours print ok which means the laser unit is functional.
                      I would still be looking at the I.D sensors.
                      Specifically the wire harness that connects the sensors to I/O and BICU board.
                      What about the I/O board have tried one of those?
                      Failing that I would rip out the wire harness and fit a new one.
                      I'm not saying I'm correct as I have not had to fix this service code before, but that is what I would be looking at.
                      Anyway please let us know the outcome as your experience of this fault may help others / me in the future.
                      • SuperLeo
                        • xximhxx
                          • Apr 2011
                          • 24
                          Re: SC 400 on MP-C2500/4500
                          where can i find the id sensor ?
                            • 37052
                            Good morning grave robber. I take it that you did not notice that this thread has been dead and buried for over 6 1/2 years. Start a new thread and we will help you.
