Help settling argument on sd cards
  • nmfaxman
    • 1702
    I say d009 thru D013 need print/ scan sd card in slot 1.
    Other tech says no sd card needed in d011 and d013, and slot 1 is for PS apps.
    Who is right?
  • rthonpm
    • Aug 2007
    • 2859
    Re: Help settling argument on sd cards
    The D011 and D013 models are preconfigured so there is no need for an add-on SD card. The D009 and D012 models will need the SD card to use the print and scan functions. If you need more information, check the Product Support Guide for the family.
