Can transmit but cannot receive fax (MP C4501)
  • sharpmind
    • Sep 2009
    • 478
    Guys, what settings do I have to change in configuring fax in MP C4501. The client can send but cannot receive faxes. The receiving tone keeps on ringing but no fax receive. The machine is new and so is the fax line.
    Any ideas?
    Thank you!
  • Jomama46
    • 2900
    Re: Can transmit but cannot receive fax (MP C4501)
    User tools>fax features> reception mode> should be in auto reception
    Make sure line cord is in "line" not "tel"
    check phone line for reversed polarity.
    sigpic
    A+; Network +; PDI+
    • ucinn
      • Jun 2009
      • 383
      Is it actually picking up the call and then disconnecting during communication or not answering at all?
      • sharpmind
        • Sep 2009
        • 478
        In the display, it shows "Receiving" but it prints nothing and the receiving tone just keeps on ringing like a busy tone.
        • Jomama46
          • 2900
          I think you need a new fax controller board, the CML relay is not transferring completely.
          sigpic
          A+; Network +; PDI+
          • sharpmind
            • Sep 2009
            • 478
            But the machine is totally new.I just installed it recently.
            • Jomama46
              • 2900
              Then reseat everything on the fax controller board, otherwise....
              sigpic
              A+; Network +; PDI+
              • mikadonovan
                • May 2008
                • 2931
                Let me ask you this. Is the problem with just one person sending the fax, or with ANYBODY sending a fax to the machine. Could be a problem on the other end, or with the new fax line.(I hate having to deal with fax problems because sometimes it's a line problem and the carrier won't admit it). Turn off ECM and slow down initial RX speed to 14400.
                NEVER ASSUME ANYTHING
                • patterson70
                  • May 2010
                  • 605
                  Yes, it could be a low voltage problem also. Have you tried plugging in a small fax machine and test it to see if it receives ok?
                  • sharpmind
                    • Sep 2009
                    • 478
                    I went back to the client and we checked the newly installed machine with fax.We found out that the machine can receive faxes within the area but cannot receive faxes outside the area.Let me cite an example for clear explanation.
                    The client has a branch office in Jeddah, Saudi Arabia where the machine was installed.The area code of Jeddah is 02. The client's head office is in Al khobar, Saudi Arabia which has an area code of 03. Faxing within an area code of 02 has no problem but with area code of 03 is a problem. Sorry to say, I have less knowledge about telecommunication.
                    The client has already called the service provider to fix the issue on the fax line.
                    Sorry for my ignorance on this matter...I think i need to sharpen my mind.
