MPC2050
  • GeorgeBest
    • Jul 2009
    • 517
    MPC2050
    Customer called for SC400 error on this machine !
    I cleaned the ID sensors and its guide bracket.
    Made test prints and copys with no errors.
    However, today a new call that the error returned.
    Never seen this problem on this machine, so the ID sensors must be replaced or need it to be adjusted ?
    Anyone, thanks in advance
  • sharpmind
    • Sep 2009
    • 478
    Re: MPC2050
    I have encountered the same problem and I tried to clean the ID sensor but the error showed intermittently. Performed some adjustment but no luck.I replaced the ID sensor board in order to resolve the problem permanently.
    • ucinn
      • Jun 2009
      • 383
      Re: MPC2050
      Also check your transfer belt for bad spots. I have had the ID sensors go bad and also a bad belt cause this.
