i check print counter also slant , but paper come out never slant , registration bush never broken . say thank first to any one help .
A 1018 image slanting
Tags: None
Re: A 1018 image slanting
Have you checked the side to side registration (SP 1-1002)?Have you also checked both registration bushings (rear and front)?Are friction pad and feed roller still good? -
Check both cassettes is the slant in both cassettes ? if yes stop the copy before the fuser unit is the slant there? if yes then your reg bushing are worn allowing uneven pressure if no then its in your fuser unit.Comment
Paul@justmanuals.comComment
i very sure paper come out never slanting , print counter image also slanting , real and front bushing no broken , my friend said change LD unit assy can solve this problem , but i haven't try yet .Comment
you are right my friend this spring always broken and it hanged with plastic part not much strong to standing...thus and check that small two gears not fret.and i attempt to swap it with another solid part it's make noise when working.this causes slan image and misfeed registration reign.Comment
You can adjust position of Laser Unit, but it takes a long time to get it right.
As for the Reg Bushings, one of the worst design flaws ever in a photocopier.Comment
i want said to all for THANKS , cause i already solve the broblem , i try to stop the paper at the half way, then i saw the paper actualy is slant.Comment
