Unfused copies in MP3350
  • worksmart
    • May 2010
    • 16
    [Misc] Unfused copies in MP3350
    Hello Friends,
    Here is some strange problem with MP3350, Images/prints are unfused. (toner on the output gets easily wiped off)...
    Checked - Fusing lamp, thermistors, pressure roller's pressure, even No error code is generated for low fusing. Done fusing idling. And this problem is not on every output. It occurs occassionally, as when machine is recovering from Energy save mode, or sometimes when machine is restarted.
    Any feedback from all.
    Thanks.
  • Eric1968
    • 2458
    Re: Unfused copies in MP3350
    Did you check the environment (like airconditioners, heaters etc)? Are you using the original toner?
    • NeoMatrix
      Senior Tech.
      • 3513
      Change user printer settings to from thick paper to plain paper.
