Ricoh AF2090
  • msmy
    • May 2010
    • 123
    [Error Code] Ricoh AF2090
    Hi,
    I have Ricoh AF2090 and giving me lot of problems.
    First is print/copy blur after 1000 copies. Then I need force toner or printer free run.
    action: I changed new toner pump, drum and developer.
    Result: SAME. .
    Second: when I switch on the machine, the machine freezes. Just "please wait" at the screen appeared. So I have to switch off/on the machine many times.
    Third: The error codes appeared; SC995, SC990, and few more.
    question: What is going on!!!!!! Any ideas will be appreciated.
    msmy
  • rthonpm
    • Aug 2007
    • 2854
    Re: Ricoh AF2090
    With the 'please wait' prompt it sounds like your hard drives are going bad: replace them as a set. I think Ricoh places a special RAID configuration on these so you probably have to order the drives from them. It may help with the blurry prints too, I've seen all kinds of strange things happen when the drives or memory DIMMs go bad.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Ricoh AF2090
      Paul@justmanuals.com
      • msmy
        • May 2010
        • 123
        Re: Ricoh AF2090
        its because of firmware or orther else? If firmwire how to reload it? I asked the authorise dealer here, but they dont know hoe to reload firmware (or maybe they dont want to help). Anyone could help me....
        • vargue
          • Oct 2011
          • 404
          Re: Ricoh AF2090
          look my friend we have two problem first blurred image then( please wait) first detect that tank is not leak toner or devolper in clutches .and sc990 these threat have many causes first drum is too old and this assumption is so far.because yo changed. check out machine lock door. and there is dust on away between drum or laser unit.and please wait try another hdd it's works definitly
