duplex problem~please help~
  • stupidkiller
    • Oct 2011
    • 57
    can i install ricoh 270 duplex on ricoh 1027 ? any modify needed ? help please thanks~~
  • sandmanmac
    • 3981
    Re: duplex problem~please help~
    I`ve swapped the duplex interchange unit, bypass tray, lower paper trays, shift sort tray, but never the entire duplex unit. I imagine it would be fine. Only one way to find out -try it
    • stupidkiller
      • Oct 2011
      • 57
      i've tried it,but the paper keep stuck.i just want to comfirm here if it is possible or who ever did this.
      anyway thanks for ur reply,appreciate =)
      • sandmanmac
        • 3981
        Why not include that information in the original question? That now opens the door for all sorts of questions: why are you replacing it? Did the same problem exist? Are you sure it's actually the duplexer jamming and not the interchange unit? Where does the jam occur. Much More information is required to give you advice.
        • stupidkiller
          • Oct 2011
          • 57
          thanks for the reply!
          i will have a new try again but next week,i will write up the exact and clear message here and i hope to get ur help and reply.
          thanks alot =)
