Aficio 2022 won't network prnt on Windows 7 64 bit
  • copyaction
    • Oct 2007
    • 991
    Customer installed new computer windows 7 - 64 and it won't print to the 2022.
    I tried reinstalling the printer and 3 different drivers (pcl6 - 64, pcl6, pcl5e)
    I can pull it up on the web image monitor and everything shows ready, but when I try to print it just sits there.
    They have 3 other computers and all are printing just fine.
    (PS, I tried posting this post 3 other times and it keeps coming up in "PRINTABLE VIEW" and can't be responded to or edited or deleted, sorry)
  • vargue
    • Oct 2011
    • 404
    Re: Aficio 2022 won't network prnt on Windows 7 64 bit
    tell the client install new software win7 32 bit that's all
    • Mooseface2r
      • Jan 2011
      • 114
      I have had this on newer OS, try turning off snmp under port configuration and see if that helps.
      I had it where the printer was showing offline on one pc turned this off and all was ok...bit of imcompatibility ibetween them reguarding snmp
      • rthonpm
        • Aug 2007
        • 2859
        Another thing to try would be changing the port type from RAW to LPR. I think Windows 7 may use a different port for RAW printing than the older operating systems. To make this change:
        Devices and Printers
        Right Click on the 2022 and choose Printer Properties
        Ports
        Configure Port
        Protocol change from RAW to LRP
        LPR Queue name lp
        Press Apply and close all windows
        Hopefully that will help.
        • Chameleon
          • Nov 2011
          • 200
          What happens if you use one of the preinstalled Win 7 drivers instead of the ones downloaded or from the CD? When you add the printer instead of "have disk" use one of the printers from the list, any HP laserjet like a 2200 or 4100, or a Ricoh 2550 or 3010.
          Another port to try is the optional LPR port. For Win 7 - Control Panel Home, Programs, look for "Turn Features On or Off". Then expand the "Print and Document Services" and check LPR monitor.
          The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
          • nmfaxman
            • 1702
            I have seen Norton cause this.
            Just trust the copier's IP address in Norton's firewall.
            • jonezy999
              just one copy??
              • Feb 2010
              • 952
              http://www.copytechnet.com/forums/ca...sting-tip.html
              I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
              • copyaction
                • Oct 2007
                • 991
                Thanks jonezy, good to know.
