I am working on an mp4001 with a 3010 document feeder. The registration is off 5mm through the doc feeder. The original is early. I adjusted the registration in sp mode, but I run out of adjustment before I get it correct. I can get it to 3mm but no closer. It doesn't vary, it is the same each time. Any help would be appreciated. Roger
