ricoh 3045 jam wont clear.
  • Rambo
    • Sep 2011
    • 15
    I have a ricoh 3045 thats saying to clear a jam in the lower right door, in the fuser.
    There is no jam and i took the whole assemblys out and checked them over real carefully.
    everything is clean but the machine is still telling me that the jam isnt cleared!!!
    i cleaned some of the sensors to, and the fuser isnt warming up.
    also.. i took the back cover off the machine and i saw 2 loose wires, male and female connectors not compatible with each other, can this be part of the problem?
  • vargue
    • Oct 2011
    • 404
    Re: ricoh 3045 jam wont clear.
    detect that no papers stacking up in exit unit........ did machine give yo open door signal!!!!!!!!
    • Eric1968
      • 2458
      Look in the jam history to see which sensor is registering the jam. Then do a sensor check on that sensor.
      • TonerMunkeh
        Professional Moron
        • 3865
        Can you take a picture of the ops panel with the jam code and another picture of the back cover off and these loose wires? Might give us a better idea of what's going on.
        Hit it.
        • ricohmaina
          • Dec 2011
          • 20
          Check your door switches.
          • Tec1
            • Dec 2011
            • 48
            Double check vertical jam right where main side door hidges (below transfer belt area)
            or possibly torn paper right out of cassette paper feed guides
            • duct tape
              • Jun 2009
              • 87
              I've seen the door switches cause this problem repalce all of them left front an right ones by the fuser.
