mp2550 jamming
  • amps
    • Feb 2010
    • 6
    [Jamming] mp2550 jamming
    mp2550 intermitantly jamming at machine exit to bridge unit entrance you could run 250 duplex copies with no problems then bang it will jam then run and run and run or as the custpmer say it will jam after jam after jam, firmware is the latest, paper side size sensor ok PCU, fuser rollers and strippers all just changed, interchange unit, duplex unit, bridge unit all been stripped cleaned and lubricated customer only does duplex copies on this machine (very little simplex) any ideas out there
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mp2550 jamming
    Hello. I'm having the same problem now. Between the fusing unit and the exit of the interchange unit the leading front edge of the paper sometimes gets a curl when bizzy with duplex and sometimes even jams...
    • HP:guy
      • Feb 2013
      • 279
      Re: mp2550 jamming
      Have you replaced the bridge switches?
      • JustManuals
        • Jan 2006
        • 9838
        Re: mp2550 jamming
        Paul@justmanuals.com
