MP171SPF Error - SC 866 - "SD Authentication Error"
  • DiskCopy
    • May 2011
    • 33
    Replace the Controller Board?
  • Jaxom
    Lead Technician
    • Apr 2011
    • 62
    Re: MP171SPF Error - SC 866 - "SD Authentication Error"
    Does it still throw this code without an SD card in any slot (I would hope it wouldn't)?*
    Try updating/reloading firmware. Maybe the reader has dirty contacts. Or the reader is defective which would require a new controller.
    And reading the Goose's guide, possibly the DIMM memory on the controller.
    Have you tried turning it off and on again?
    • DiskCopy
      • May 2011
      • 33
      Forgot to say:
      - Already Rewrited all Firmwares and Replaced the DIMM , and NO SUCCESS.
      - And Without the SD , error still Occurs.
      Thank you for your help.
      I will try a Contact Cleaner Spray.
