Ricoh pro1356ex
  • CANCOUNTRY TECH
    • Aug 2008
    • 114
    Ricoh pro1356ex
    Hi all,
    I need to troubleshoot sc955 question is is there a sp code to bypass the fiery controller.
    I have set up a port/print que and driver.
    But no prints.Is there a sp i need to enable for gw printing.
    Cheers
  • RG1964
    • Jul 2009
    • 56
    Re: Ricoh pro1356ex
    Originally posted by CANCOUNTRY TECH
    Hi all,
    Cheers
    When they use a fiery there's no printer/scanner sd in the machine.
    • CANCOUNTRY TECH
      • Aug 2008
      • 114
      Re: Ricoh pro1356ex
      Thanks mate thought it would come standard with this machine.
      Was only going to get it for troubleshooting until i saw the cost.
      Cheers mate.
      • STIG5897
        • Oct 2011
        • 13
        Re: Ricoh pro1356ex
        Sc955 is most likely your hdd's are stuffed, you can disconnect then and see if machine fires up..............
        • JustManuals
          • Jan 2006
          • 9865
          Re: Ricoh pro1356ex
          Paul@justmanuals.com
          • CANCOUNTRY TECH
            • Aug 2008
            • 114
            Re: Ricoh pro1356ex
            All sorted mate. I know its the hdd i was trying to troubleshoot if it was the fiery hdd or gw hdd
