Hello! I have a problem with a 3245c, the machine was running on the client until yesterday ... the problem comes when they want to print heavy files , the data start to be generated on the PC, but if the file weighs 160MB generated only generated 158mb, the printer turns on a light green, but then the file disappears from the queue printing and the printer is listed as if nothing had happened, without leaving the impression, lighter sending files (30 mb already generated) but prints takes , nose if I did understand, this happens from a pdf or from the adobe illustrator, try from the PC and from a laptop connected directly to the computer via USB but it did not work
forgive the translation! aluna idea? I aim to hdd ...
