Outbound email fax confirmation per user code on Ricoh MPC3500
  • seahunter
    • May 2011
    • 18
    Customer has an Afico MPC2500. Customer requires user code entry for all operations, including fax. When you login to send a fax you have the option of pressing the "Sender" button, choosing an email address, and then having an outbound fax confirmation sent to the chosen email address. Is there any way to have this confirmation sent by default (user is not required to choose it) to the email address of the user code that is logged in when sending the fax?
    “You pigs, you. You rut like pigs, is all. You got the most in you, and you use the least. You hear me, you? Got a million in you and spend pennies. Got a genius in you and think crazies. Got a heart in you and feel empties. All a you. Every you...'
  • Jaxom
    Lead Technician
    • Apr 2011
    • 62
    Re: Outbound email fax confirmation per user code on Ricoh MPC3500
    Hmm, I don't think so. Pretty sure you could set a default sender and have all confirmations go to one email, but I'm about 99% sure that that is as far as you can go with that.
    Have you tried turning it off and on again?
    • teebee1234
      • Jul 2008
      • 1670
      I'll have to check later on the possibility of that, but if the user utilizes LAN fax then they can get an email confirmation sent back automatically.
