Ricoh MP7000
  • luke001
    • Dec 2011
    • 46
    [Electrical] Ricoh MP7000
    Machine will not wake on from sleep mode when I put the original to DF or open it. The machine is the latest firmware. Can You help me any ideas?
  • spaceman99
    • Jul 2009
    • 174
    Re: Ricoh MP7000
    hi..try your door switches. also try to see if you can get into sp mode and get a error code. may be check the fuse on the lwr psu for the controller.
    good luck
    • luke001
      • Dec 2011
      • 46
      Re: Ricoh MP7000
      Thanks to spaceman99. I'll try next week. Today I checked : From sleep mode machine wake up and from Off mode machine not respond.
      • Jomama46
        • 2900
        Re: Ricoh MP7000
        Check the Switch at the rear center of the DF, it detects when the DF is opened or closed.
        BTW, it wont come out of Auto-off by opening the ADF, only out of ES mode.
        sigpic
        A+; Network +; PDI+
