MP 4000 Doc Feed Jams
  • iscott
    • Mar 2010
    • 344
    Customer is doing large volumes of 2 sided scans.
    Doc feeder is jamming frequently. It is jamming just prior to the leading edge appearing in the exit portion of the ADF.
  • Jomama46
    • 2900
    Re: MP 4000 Doc Feed Jams
    Check the black pockets under the photoreflectors, they get filled with paper dust and will cause a false reading. This is very common and I think is your problem.
    Secondly, check the jam codes they will give you and us a clue.
    sigpic
    A+; Network +; PDI+
