mpc 6501.....please wait.....well im done waiting
  • redneckstylin
    • Sep 2011
    • 173
    got this pos mpc6501
    high volume account and originally we had a sc569 which led to bent pr roller rod
    replaced bent rod,fuser that is brand new,hp sensor new bearings woooohhooooo time to fire it up
    .....please wait...... well now it dont go past that arggggg not a good day........now it has a tendancy to through me a 670 and 672 and sit at please wait .....
    any help appreciated
  • RRodgers
    • Jun 2009
    • 1947
    Re: mpc 6501.....please wait.....well im done waiting
    I believe a bad hard drive on a Ricoh will give ya a please wait..... Try disconnecting them (or it)
    • CANCOUNTRY TECH
      • Aug 2008
      • 114
      Have had 569 error in the past and have tracked it back to a faulty vbcu board on this particular model.
      • sandmanmac
        • 3983
        "please wait" often point to an HDD problem, so I'd strat by disconnecting them and trying to boot it up as suggested; However, the Sc codes you're getting all seem to point toward the VBCU also as suggested as follows:
        SC 569 Pressure roller lift error 2 - Pressure roller lift motor defective
        SC 569 Pressure roller lift error 2 - Pressure roller lift motor movement obstructed
        SC 569 Pressure roller lift error 2 - Pressure roller lift sensor connection loose or broken
        SC 569 Pressure roller lift error 2 - Pressure roller lift sensor dirty or defective
        SC 569 Pressure roller lift error 2 - Replace VBCU
        SC 569 Pressure roller lift error 2 - Transport / fusing tray connector had paper in it
        SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness
        SC 670 Engine start up error - Check wiring for df feed in cover..
        SC 670 Engine start up error. Check main power supply, cn 409 for 5volts
        SC 670 Engine startup error - IOB board defective
        SC 670 Engine startup error - LCT lift tray sensor was shorted
        SC 670 Engine startup error - Replace finisher main board
        SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement
        SC 670 Engine startup error - sudden communication reset between controller and VBCU
        SC 670 Engine startup error - VBCU defective
        SC 670 Engine startup error - VBCU installation incorrect
        SC 672 Controller issue - reseat the fax battery board
        SC 672 Controller start up error - Check for pinched harness on duplex/fuser exhaust fans
        SC 672 Controller start up error - If Fax is Installed reseat MBU PCB.
        SC 672 Controller start up error - Suggest to replace HDD
        SC 672 Controller startup error - Install System/Copy firmware version 1.04 or later.
        SC 672 Controller startup error - Replace controller pcb
        SC 672 Controller startup error - Replace IPU board
        SC 672 Controller startup error - Replace memory dimm
        SC 672 Controller startup error - Replace mother board
        SC 672 Controller startup error - Replace network card
        SC 672 Controller startup error - Replace operation panel
        SC 672 Controller startup error - Replace print scan sd card
        SC 672 Controller startup error - Replace VBCU board
        SC 672 Controller startup error - reseat MBU board
        • redneckstylin
          • Sep 2011
          • 173
          unplugged hd units still please wait vbcu shall be arriving tomorrow
          • redneckstylin
            • Sep 2011
            • 173
            vbcu has arrived well see yall later
            • redneckstylin
              • Sep 2011
              • 173
              vbcu = fail
              argggggggggggg
              • nmfaxman
                • 1702
                Sounds like a pincher. (Pinched connector.) Most likely the 24v supply to the lift motor. Happened when you rebuilt the unit, happens to the best of us.
                All the codes you mentioned are 24v controlled or drive monitor signals.
                I tend to mount the brackets by hand and tap them before I tighten screws. A clean mount will sound metal to metal. A pincher will sound dull.
                As always.................
                • turbojetboy
                  • Aug 2009
                  • 279
                  I have seen this twice, 1st time it was a faulty fax board, if you have fax fitted remove the fax kit (including the bridge board). 2nd time was after a tech replaced controller, ram in wrong slots - make sure 512 card is in LHS slot and 1gb card in RHS slot. Good luck.
                  • redneckstylin
                    • Sep 2011
                    • 173
                    ill head over there tomorrow and try looking at everything with wires....
                    ill check memory make sure in right slots
                    and ill try running without fax ill update everyone tomorrow
                    • Timmytronic
                      • Oct 2010
                      • 249
                      Hiya. I had this. Have you reformatted the HDD and updated the firmware? Worked for me.
                      Be good to know if you sorted it to help others :0)
                      • RICOHTEC
                        • 42
                        hi
                        i have a similar probleme and it was a probleme with one of the two memory card on controler
                        • redneckstylin
                          • Sep 2011
                          • 173
                          reformatted hdd and new eprom got er up and running
                          thanks everybody for the helpful thoughts
                          • ptrflrs
                            Glorified Parts Swapper
                            • Dec 2010
                            • 192
                            I was worried after looking into this code here. I had this sc569 yesterday on a mpc6501 and I guess I got lucky -it was just a sheet that fell behind the transfer/fusing area that slides out and into the connector back there. Whew!
                            jesus loves you! (everyone else thinks you're an assh*le)
                            street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
                            Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
