Scan to Folder - Ricoh 3245C
  • rgteksol
    • Jun 2025
    Just installed Win 7 Pro x64 machines and scan to folder does not work. Turned off password protected sharing on the machine where the folder is shared - with everyone, full rights. Still no gas.
    I believe there must be a firmware update to this machine, but cannot find it anywhere online. Guidance is appreciated.
  • DrJive
    IT Team ******
    • Jul 2011
    • 15
    Re: Scan to Folder - Ricoh 3245C
    You need NIB 4.20 firmware
    http://www.ricoh-support.com/tempfiles/RB178005e.pdf
    • rgteksol
      I appreciate the feedback DrJive. I kind of figured it was a firmware upgrade - I just don't have access to download any firmware and was wondering if I could get some help (link to download ) with this download
      • luke001
        • Dec 2011
        • 46
        ,,http://www.ulozto.cz/12886378/b7166540f-remote-exe"
        Upload via FTP to the machine.
        • rgteksol
          luke001 - I followed the link and it was to a site that is in czech, although my wife could read it, I will have to wait until she gets home from work.
          Thank you for trying
          • rgteksol
            Read through the czech file, but wonder if the firmware is also the same language
            Thanks anyway
            • NeoMatrix
              Senior Tech.
              • 3513
              Is this being used on a Home network or Public network sharing ?
              Try lowering the file encryption network to "40 -50 bits for older style file sharing."
              Have you set the correct Workgroup or Domain to match the same as all the local PC's?
              In Win7 Pro try going into control panel |turn on windows extended features| and turn on scanning capabilites.
              • rgteksol
                All PC's are on a local workgroup mode (Workgroup ) until a domain controller is put in place in the next 6 months. Never used encryption on the network.
                Thanks for the reply though.
                I called Ricoh, and unless you are a certified tech or reseller, they will not give you access to ANY firmware at all.
                • luke001
                  • Dec 2011
                  • 46
                  NIB firmware have English language
                  • rgteksol
                    kk,
                    thanks luke001 - I will run the exe file in a test environment first
                    • vijay5264
                      Hi
                      i am also in need for firmware update i tried the link but not valid anymore. is there any other source were i can get this and other latest firmwares for ricoh 3245c ?
                      • luke001
                        • Dec 2011
                        • 46
                        Originally posted by vijay5264
                        Hi i am also in need for firmware update i tried the link but not valid anymore. is there any other source were i can get this and other latest firmwares for ricoh 3245c ?
                        Here you go.[URL]http://ulozto.cz/xXSQkMG/b7166540f-remote-exe[URL].
                        • sandmanmac
                          • 3980
                          Hi
                          If you continue to have issues with SMB setup, Scan To FTP is always an easy and reliable solution, and firmware is never an issue.
                          I use Filezilla FTP Server. It works flawlessly
                          • vijay5264
                            thank you you are a life saver
                            • vijay5264
                              a very good and valid idea i tried explaining it to the client but as u might know the look and reply can be summed up in one expression
                              " hunnnnn....?"
