SC544 on DSM616
  • matix
    • Jun 2011
    • 6
    [Error Code] SC544 on DSM616
    Help me.
    I have one machines (nashuatec dsm 616) give often sc 544 error.
    Thermistors and the power board have been replaced.
    sc544 error control circuit Thermistor Central.
    Give me one solution....thanks.
  • Jomama46
    • 2900
    Re: SC544 on DSM616
    Replace the hot roll with and OEM
    sigpic
    A+; Network +; PDI+
    • matix
      • Jun 2011
      • 6
      Re: SC544 on DSM616
      Thank you for your swift response Jomama 46.
      I completely replaced the fuser unit, and sporadically continues to sc544.
      I now have another dsm616 with sc544 ... :-(
      • Jomama46
        • 2900
        Re: SC544 on DSM616
        Fuser plus power board, eh? You are left with line noise, get a quality filter. (not a power strip. This is an overheat error and the SSR is on the power board.
        sigpic
        A+; Network +; PDI+
        • matix
          • Jun 2011
          • 6
          Re: SC544 on DSM616
          Ok, thanks. Now I try and let you know. I'm sorry for my bad English :-)
          • matix
            • Jun 2011
            • 6
            Re: SC544 on DSM616
            Installing a new dsm616 the problem is not found.
            The old dsm 616 continues to sc 544 error.
            New fuser and new power supply in the old multifunction, continued sc544 approximately every two days...
            • katash
              • May 2010
              • 221
              Re: SC544 on DSM616
              check your power source,might be insufficient
