MPC4500 SC581 Help
  • Belmont Turbo
    • 11
    [Error Code] MPC4500 SC581 Help
    Hi all im having problems with an mpc4500 with sc581 we have changed the ih board, ih coil, the power supply board the fusing unit, latest firmware and its back in again today with sc581! any one got any idears because its driving me mad now. Have spoken to ricoh they said to change ih board then power supply done that and it lasts a day then sc581 again!!
    HELP
  • ucinn
    • Jun 2009
    • 383
    Re: MPC4500 SC581 Help
    HELP
    Check the fuser cooling fan.. it will still be running but the blades can break off the hub so the motor runs but the fan isn't turning. I believe we have had 2 of these do this.
    • rsyarcia
      Hair Straightener Tech
      • 711
      Just check what I told you in you previous post. It may help you.
      Nobody is perfect..
