Ricoh MPC 7500 J001 with no signs where to remove paper
  • webtech
    • Jul 2019
    • 4
    #16
    Re: Ricoh MPC 7500 J001 with no signs where to remove paper
    Originally posted by Zaxxon
    You are on the right track, these boxes needs to be turned off for approximately 8 years to be reset...
    aha aha sure but i love the print quality.. i have a xerox dc252 and i love the ricoh since its parts and toner are much cheaper compered to xerox
    • webtech
      • Jul 2019
      • 4
      #17
      If jam D is a Fusing exit jam, the fusing exit sensor is failing. Whether it be a reed switch or optical sensor when they get old they tend to fail when they have been hot for a length of time. Once they cool down they start working for a while. The length of time they work slowly gets shorter. Common with optical sensors on older 35/45 ppm models and reed switches on older martini models.
      i already changed the fusing sensor from another machine but the problem was same.. but i have since cleared the error by cleaning the paper trays with a blower. many thanks
