Ricoh Aficio 2045e
  • toshiba
    • Dec 2006
    • 58
    Ricoh Aficio 2045e
    In Ricoh Aficio 2045e with printer, scanner and fax, The copier, document server, fax and scanner work well but when I give print, the m/c shows "Printing" but no print coming our. I tried both in PCL6 and RPCS. I tried replacing controller board, network card, harddisk, I cleared memory clear for printer application, connected the m/c with another port but after all these, still pbm exists. What can be the possibility?
  • copyman20
    • 207
    Hi,
    Make sure you don't have user codes enable for the printer mode.
    good luck
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      I get sent out to alot of these types of problems and 95% of the time it's not down to a hardware fault.
      If you print off the SMC diagnostic report that will tell you if have a hardware failure.
      Things to check and try...
      Update the firmware and drivers to the latest versions.
      (There are certain fixes for known issues via firmware and driver updates).
      Originally posted by RTB2e
      Images that contain PCL forms via host printing might not be printed.
      (GFPR#RE04040009)
      If PCL data is printed under the following 3 conditions, some problems
      may occur. (GFPR#RE03090010, RE03090012, RE03100012,
      RC03100014 and RC04040013)
      ! PCL/PS auto switching is ON.
      ! The job is text data and the 255th byte contains all zeros.
      ! The <ESC>E command occurs somewhere in the first 128 bytes.
      Solid or broken lines might not be printed with PCL forms via host printing.
      (GFPR#RC04040011)
      1.03
      The printer may stall and have to be rebooted after multiple forms(or
      templates) are sent to the printer (GFPR#RA04070002 and RE04090011)
      Try printing documents from different applications like Word, Excel, Acrobat.
      (A lot of the time I find a printing problem only occurs from one specific app, document or users PC).
      Check the NIB link speed.
      (10mbit half duplex does not cut it and will cause scanning and print spooler hangs).
      Go through the user settings on the machine and check nothing is enabled that shouldn't be.
      Tip
      In my opinion on Ricoh's you get less printing problems using their own RPCS raster driver over the more generic PCL5/6 drivers as they seem to update them far more often and they fully support the range of MFD features.
      The only other driver that I find is reliable but once again misses some features is the PS3 driver (PS3 option not included as standard).
      • oldtek
        Ricoh Aficio 2045e won't print
        This has caught a few people. Secure Printing on Ricoh MFD Copiers - CTSKnowledgeBase
        • petrus
          • 155
          driver
          try to uninstall and re install the printer driver.
          • toshiba
            • Dec 2006
            • 58
            Hi friends,
            Thanks a lot for your sincere suggestions and after my two days struggle, When I gave a new IP address for this machine, it started working. Funny issue!
