3235c when scanning or making copies there is a yellow lines across
  • yannii33
    • 121
    Every so often there is a yellow image if a line that appears acrros the scan or copy almost like an image of the scanner lamp. Any suggestions what this might be? any help appreciated
  • Jomama46
    • 2900
    Re: 3235c when scanning or making copies there is a yellow lines across
    CCD
    sigpic
    A+; Network +; PDI+
    • ucinn
      • Jun 2009
      • 383
      Speck on glass slit, or possibly dirt on mirrors.
      • kyoceran
        • 100
        check to see if ads is turned on, this can eliminate a lot of minor CQ issues. good luck
        • yannii33
          • 121
          Whats ads?
          • Counsel
            • Aug 2011
            • 530
            First if the line occurs both on the doc feed and the platen glass your issue is dirty mirrors, if the line only occurs using 1 or the other of those then its on the glass itself. Dust or dirt can come out what ever color the machine thinks its seeing. If its only when scanning or copying its likely something on the glass or mirrors it will also only print the line within the printed area and not in the erase margin, lines caused by drums/charge rollers etc will run all the way across the page even through the erase margins.
            • yannii33
              • 121
              Its a problem in the scanner i think ots doesnt happen on every scan the print is good and both glass and adf same thing doesnt look loke a straight line more like an yellowish exposure lamp bottom of the image
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                Listen to Jomama46. CCD will cause this exact issue. ADF and glass, same problem.
                I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                • yannii33
                  • 121
                  Thank you
                  • Counsel
                    • Aug 2011
                    • 530
                    Makes sense then what the previous guys said, i read a little fast and didnt register the part about it being Every so Often, not an all the time issue brain fart on my part.
